- 6:58 PM
- Jan 28, 2016
- Dike, Iowa
That’s interesting! Haven’t seen that! Makes me wonder what came first, the high idle cp or the standard sp125. Or they overlaped? Probably!It has the boss for the high idle, but it was not drilled out. I made a sort of drill guide and drilled it, then noticed the throttle trigger did not have the provision for the speed screw. JJ is taking care of that for me.
Mark
Working on a fix Mark, will give an update when I get everythingHere is the latest SP125, I am thinking that this one has been worked on a time or two in the past. It came to Iowa from Saw King with a stripped spark plug thread among other issues. I don't believe the black shroud is original...on that subject has anyone come up with a good method for restoring the nuts in the shroud? This one is missing both and I would eventually like to be able to secure the flywheel housing to the shroud.
Mark
Mark
I have some similar plansGuys -
I'm looking at using Tee nuts with tubular rivets or cold rivets (tinder rivets) mounted to the shroud where the captured nuts have broken off. I'll let you know how it goes.
https://www.mcmaster.com/tee-nuts/screw-mount-nuts-6/
Is there any reason you couldn't JB Weld some square nuts in there?
The hole is too big for that standard ones, Going to try some longer versions with two washers and see if that holdsHave you considered rivet nuts (rivnuts)?
I know they flog install tools for those but a screw with a couple of nuts to jam them onto the threads against the head works well too. They can be had with very thin heads.
View attachment 305066 View attachment 305066
It’s about a 3/8 of an inch hole, Are used JJ’s idea with rivets seems to work pretty wellView attachment 305108View attachment 305109
I tried that first, and I don’t have deep enough grip nutserts Need to order up some different ones, mine are for .020-.130 And that wasn’t enough to grab two washers, they make .130-.225 But they are much less common. I can also have my buddy tig an aluminum nut in there, which would probably be the best solution, Or tig plate across there and put a standard nutsert inI think rivnuts with washers would work well.
