8:34 PM
I might add on that thing if it has 1/2" chain and it is okay fine .If not you can find the .404 spurs for them which pop up on flea bay from time to time . Being a gear reduction type ,trust me you won't use it much
Those old gear drives are not the fastest but with a good chain will chew through anything .
fossil
8:34 PM
Ontario, Canada
This little Mini Mac 6A came out of a country dump.
I thought I would prime it to see if it had spark and it fired up and kept on running.
It kind of shocked me. 1/4" chain (I think) in nice shape.
The saw is in decent shape for a nearly 50 year old saw.
It's raining out so crappy vid attached
northwest saws
8:34 PM
North Idaho
Thank you . I will start looking into it when I get back home Friday. Gonna kill me to know it's sitting there and I can't mess with it cause of working out of state. Updates and more questions to follow.
Look forward to seeing what you find! It looks a little dirty but the paint seems like it's in good shape. Like Al said you might be surprised. A good cleaning and you may have a slick old saw! It definitely looks like it's in better shape than the one I have out in the shop. Mine is very crusty and is going to take some elbow grease! I know a fella that can spin up a loop of 1/2 inch nos chain for ya if need be.
Sent from my SM-N910V using Tapatalk
41FanForLife
8:34 PM
Don Martin's House
I haven't looked into it at all. Chain looks pretty decent on it. Know the bar is 25". Does the choke lever not lock when you depress it?
northwest saws
8:34 PM
North Idaho
Nope it doesnt, you have to hold it. The old super 44 and 55, 1-70, 1-80 and a few others are like that.
heimannm
7:34 PM
Dike, Iowa
42 - Hold the choke closed and throttle open with your left hand, pull the starter with your right hand. It helps to have the saw laying over a log or on a bench...after you give it a thorough check over. You will find a large felt wick/filter in the fuel tank, hopefully it is not laden with old, stale fuel or varnish.
Mark
Dream
8:34 PM
Elberton, GA
View attachment 241621 View attachment 241622 View attachment 241623
That one is way nicer than the one I rescued from a scrap pile. Doesnt look like yours has been used much. I found mine and a PM6A sitting side by side. They both have 1/4" chain. Look to be in decent shape.
fossil
8:34 PM
Ontario, Canada
Mine came with a PM 6 as well but it's in rough shape. Broken parts.
Dream
8:34 PM
Elberton, GA
Never even had fuel in it and I sold it...
Mark
That would be akin to having a loaded hand grenade and selling it to someone else who would hopefully keep it and not use it.
I probably couldnt keep myself from pulling that pin.
I HAVE to use them.
Thats what they were made for.
I cant stand the plastic garbage that goes for "pro saws" these days.
Dream
8:34 PM
Elberton, GA
Dont suppose theres a good recoil pulley in there? I thought I had a donor, but it was just another MM.
41FanForLife
8:34 PM
Don Martin's House
Good morning guys. Just rolled back in to town. Threw the air filter cover in the ultrasonic cleaner for a few minutes. Piston looks good from what I can see through the ports. Definitely need to track down a muffler.IMG_20200522_091431040.jpg
Gizzard
8:34 PM
KY
I'll go through stuff this weekend...I would have that...just have to make mind up how many I need. Either way I'll send you a message after looking.
Gizzard
8:34 PM
KY
I hear that all the time. I just tell her that once it is gone, I'll probably need it the next day.
8:34 PM
I 'd imagine just about any of the round mufflers would work .For that matter a person could most likely make one if nothing else .Keep in mind those old reed valve engines seem to run better with more open exhausts and tuned more rich than a modern saw .They might idle and blow black smoke but once you gas it and it gets wound up all that turns into power ,with of course a good bit of noise to go with it .Ear plugs and muffs might be a good idea .
41FanForLife
8:34 PM
Don Martin's House
Silly question for you. Having never owned a saw this old what ratio mix should I put in it? I know we used to run the old dirt bikes pretty rich. Just don't want to do anything stupid and junk this old beast
PogoInTheWoods
8:34 PM
Ohio
Modern synthetic oils allow for much leaner mixes and cleaner combustion, but lots of guys still run 32:1 or less in their old saws.
I personally run 40:1 ethanol free / high quality synthetic oil in all my saws, including some pretty old ones.
And please, let's not let this get away from us! LOL
