Vinnywv
- 12:06 PM
- Dec 22, 2021
- West virginia
Ive got a saw story to share. Win in the end....last week i got a mcculloch g70 off ebay. Been wanting one for a spell. It was buy it now for 150+ shipping. Looked a bit rough. However, i was not afraid of a bit of dirt. The seller stated good compression but no spark, non running. I figured it would be a junk cylinder and piston. I have 3, 7-10 saws that all run very good. So i bought it planning on an engine swap. Didnt realize it would not be as simple as id expected. So i started taking apart the g70. Nearly a complete saw. Missing bar plates was it. I got into it a bit and found gritty sap all over under in and out of this poor southern saw. Cleaned off fairly easily. But it was thick. The recoil was a bit weak. Opened it up to wind it a turn and found a broken ear on the pulley. Alas, i had a new one!! Win. The oil pump was missing the little disc. Had a spare there. Win. The fuel tank was absolutely disgusting. Thick corrosion top to bottom. Plus a few pin holes. No problem, the 7-10 is good ill use it. The cylinder had a massive gouge in it, "great compression".. yea right. The piston was toast. Air leak on fw seal. No problem ive got one. After comokete dissassembly i had a box of dirty parts, but a 7-10 for help.....So i began taking the 7-10 apart at 430pm yesterday, stopped at 10pm with a nearly complete new saw. The cylinder from the 7-10 donor was slightly different and needed some material removed from the pto bearing side. Belt sander and 45 minutes later it fit very well. I was very happy with that. Took my time there. Next came piston swap due to g70 crankshaft being very different. No big deal, one pin out one in and viola. Gooped up the surfaces and stuck it together. It turned nicely now. Then all the little bits followed. Now, the fit from a 7-10 that had a dsp on the stop button to the matching cylinder was a must. But it fit just fine, heck it just came off that saw. Then the big gear box...no issues really. It attaches to the oil tank not the cylinder so it was just figuring out what went where and in what order. Today i cut a new oil tank gasket and had to test run it!!! It fired up on a few pulls and everything rotated as expected. Spent a bit getting a chain on it but boy it runs good. Borrowed bar pkates from a 250, and a bar off a sp105 to test run it. The spur gear came off a 55 and it took a bit of cleanup to fit properly. Ill replace it with a new one. Already got it in the works. I cut out a crude oil pump gasket but ive got a good one also on its way. Plus a good handle bar from mark h. Ill post pictures in the next slide. But after 2 full days a taking apart, fitting, and putting back together....i now have a great running and functioning and clean mcculloch g70. Pictures to follow.....
