Darin
JACK KNOB PRICK
10:20 PM
DUNSMANURE, CALIFORNIA
That pic is prior to disassembly. But when I put it back together I'm not sure which way the reeds went back in. Does it matter if they are flipped or not?
Lee H
10:20 PM
cape cod ma.
Doesn't matter as long as they sit on the surface so they will seal.
fossil
1:20 AM
Ontario, Canada
As far as the idle goes, make sure the throttle linkage isn't bent and not allowing the the throttle plate to close off.
Lee H
10:20 PM
cape cod ma.
Are you using the rubber mounts or is it bolted right to the tank.
Darin
JACK KNOB PRICK
10:20 PM
20161219_174039.jpg It has the brace that has 4 bolts to the tank and the ends are secured to the handlebar by hose clamps.
Darin
JACK KNOB PRICK
10:20 PM
20161219_174457.jpg Can I use a thicker gasket for mounting the reed manifold to the tank or does it have to be thin like the one on the left?
Darin
JACK KNOB PRICK
10:20 PM
Pulled the tank again tonight to see if the gasket I made was jacked up. Right side of gasket was ripped in half. Not sure if it ripped during installation or when I took it off tonight. Either way I made another one, wider on the sides so it's got a bit more meat. Carb kit and tank gasket gets here Friday. Hopefully have saw back together and running by the weekend. Can't wait to cut some *s-word up and make some noise.
Darin
JACK KNOB PRICK
10:20 PM
$_3-1.JPG Found this in Iowa on eBay for 85. I don't need the bar just the bracket. Might see if local machine shop can make one up.
Darin
JACK KNOB PRICK
10:20 PM
Found bar bracket. Looking for second felling dog for 797. All I'm finding are ones for 125s. Anoyone know if they fit both saws. Thanks
Lee H
10:20 PM
cape cod ma.
All large frame Mac's use the same dogs except the geardrives.
Never seen one with both dogs. Every Mac i have has only one dog
As it's better for felling so you can pivot the saw.
