The Official Farming Thread...
concretegrazer
11:37 PM
Mo
Concretegrazer, I have the pressure set so the gauge is a ways from the red,the bales are set so they are about two inches short. I started doing that with my old Vermeer to save the bearings. The guys down here suggested blowing the baler out with a leaf blower, as far as washing it off just the end of season with a garden hose. Guys any helpful hints appreciated! This is my first Deere baler.
Jake & Steve are right on. The ones that wash after every cutting are always having bearing trouble around here. Doesn't mater what color.
I like to lock the gate up, loosen the belts, kill the tractor & feel & spin/shake the rollers at the end of the day. It's caught 2 of the bad bearings that way.
Keep up on the chain maintenance or you'll be changing sprockets. If you have net wrap pull the brush & clean it & around it once a year. & change the belt pins every couple thousand. Cause it's a pain when they're grooved or broken.
What hay do you mainly bale?
concretegrazer
11:37 PM
Mo
All I have is a little 5x4 New Idea baler. The bales ain't really heavy enough to ever wear out a bearing.
I've got an old Heston 5510 in the barn that'll eat them. Good baler for its time. But I'll never use it again. My grandfather baled a boatload of hay with the old girl.
concretegrazer
11:37 PM
Mo
Just grass hay, and not much of that! Very dry here even the big ponds have at least ten feet off the top. Probably going to be a lot of cattle leaving this country before winter!
Then keep the compression rack in tip top shape and you'll get alone fine.
We are burned up here as well. Go north or south a bit & it looks fine. Crazy.
amberg
12:37 AM
Va.
Did about 7 acres yesterday at another little farm, then parked the tractor and baler in the shade. ( Damn hot here! ) Only 8 more acres to go!!
Steve
Excellence!
11:37 PM
Caught a small shower at home last night. Went to the land of Lincoln to get a rake today.
That's a real nice looking rake there. I hear the V bar rakes make a nicer windrow than a V wheel rake.
Must have got a great deal on it to travel that far.
Steve
Excellence!
11:37 PM
Pulled the blades of my wife's brush hog this evening for an overdue sharpening. This is the first year for her to be maintaining the field behind our house. It all pasture grass and last time I had her rig out it wasn't cutting it too well. I know they arnt as bad as you all have seen but now with an edge back on the blades it almost cuts as clean as a finish mower!
Ryan Browne
11:37 PM
Wisconsin
Nice little New Holland. I like the refrigerator rack. Is that by chance a TC 25, 29, or 33? If so, I have the 700 page service manual in PDF format if you'd care for a copy. I have a TC29 myself. Handy little tractor.
