Rich Fife
Sally slap my ass
- 4:41 PM
- Mar 4, 2023
- Central New York
Love'n it!!!
Proline sells the center section so how hard could it be?![]()
maybe? probably... I'm still new to the saw tuning / adjustment side of things and have much to learn. I'll add learn more about timing advance to my reading listSounds like it needs a timing advance.![]()
Yeah, it does vibrate quite a lotDang, that a lot of vibrations. Gonna have to check bolts every hour
Might want to figure out a way to secure that carb.
Can you turn the inside of the pin down something like the 500i’s?maybe? probably... I'm still new to the saw tuning / adjustment side of things and have much to learn. I'll add learn more about timing advance to my reading list
Yeah, it does vibrate quite a lot. Short term, I've been liberally lubing up things with blue locktite and so far the carb hasn't fallen out ... yet... but I have had a couple bar nuts loosen up which made things exciting
But it's a weight thing. Even with the amount I turned off the piston, the weight came in a bit more than I was hoping & the wrist pin that came with the piston is one of the AM thick walled ones. What can I say, I got excited to see if it would run and charged ahead.
Here's couple pics showing the size difference between the 56mm (hadn't turned it down yet) and the 48mm piston
After I got it turned down to 55mm (I had zeroed out w/the paper towel on the scale, but the plastic bags probably added some weight) so we'll say roughly 22+/- gram difference between the two
View attachment 447403View attachment 447404
I'll have to work on trying to source a lighter weight OEM sthil wrist pin for it to swap out when I go back in but... even with that change it's still a lot of weight to throw around on the end of the rod.
But this project has been fun and for me so far and the journey is always more interesting than the destination.
the first attempt works but also highlights a couple things that may be changed in round two.
Did you balance the ‘new’ crank, at speed?
Agreed and that makes sense on elongating / stretching bolt holes. I used the stock 365 base gasket but I bet seating things down it could have become slightly misaligned, inducing some of the vibration. My plan was on the 2nd round to fill in the holes in the cylinder with aluminum pins and re-drill instead of elongating bolt holes. Assuming that might be part of the cause for vibration, insuring that bolt holes are accurate will be key.Lots of vibration isn’t good. Because you kept some cylinder extension your bore should be aligned but it’s a common problem when stretching bolt holes.
500i pin may just fit. Maybe 462 is the same? There’s usually 8 or 10 grams of casting that can be ground out of the piston belly too.
I ... thought I had taken more pictures (with measurements) but apparently failed. So, I want to say it just fit the bottom end... I did have to make changes to make it fit the top end (but I don't have a good method to cut squishbands at the moment) when I go back in I can get more info for you (sorry!)I’m with @Jake Dykstra. I want a 57mm version.
@upstateamish, would you mind sharing a few numbers? How much base did you take off and where did your squish land?
Also, did you need to trim the skirts on the 661 piston? My piston skirts bottom out in the case with the 57mm slug.
before epoxy it was reading 90 so I didn't even attempt running itOkay, that makes sense. With the pin boss that much lower there’s no skirt interference. Where did the intake land before epoxy?
Definitely seems challenging to weld inside the spigot. Epoxy works fine.
I wonder if this build could be done with a 385 jug and a 660 piston.
What about the 55mm 390 piston?I've id'd & ordered a couple 661 wrist pins (on the off chance my crank experiment doesn't work out) - part number: 1144 034 1500 which is 12x8x35 in measurement.
- 661 IPL: https://www.lsengineers.co.uk/cylinder-muffler-assembly-for-stihl-ms661-ms661c-chainsaws.html
Sounds good, with all the other irons I have in the fire ... I'll continue the epoxy route for now.
I don't see why you couldn't but I guess it would depend on the diameter of the piston to cylinder that you source (e.g. from what I see the stock 660 piston is 54mm)
- 660 IPL: https://www.lsengineers.co.uk/cylinder-assembly-for-stihl-ms660-chainsaws.html
