BlackCoffin
- 2:10 AM
- Feb 6, 2020
- Washington
Been there ,I needed this threaded hole for a workpiece setup on the mill, but someone broke a tap in it.
So I drilled the taps core out in manual operation mode, used a Solid-Carbide drill bit. As I was drilling through the taps core the taps flutes got loose and snagged the drill bit breaking it.
Luckily I managed to poke the individual tooling parts free and out successfully freeing the hole and the thread in it.
Fun day at work!
Fun, innit!?Been there ,
Fun day at work!
have you tried a chip splitter end mill and H.E.M? do you use a Cad-Cam or program at the machine?Left: 10.0mm Solid-Carbide mill bit after having processed dozens of "milling lines" (hours of work throughout the shift) in grey cast iron - no cooling, high rpm.
Right: identical 10.0mm (same manufacturer & model) after milling ISO 12.9 grade steel nearly continuously for 30 minutes (about 60 mostly short milling lines) with maxed out liquid cooling and reduced tooling parameters (lower rpm's & feeds)
12.9 grade steel is unforgiving!
On the right mill bit the flutes are still fine, it is the plunge cut into the quenched 12.9 grade steel surface that takes a heavy toll on the bit.
I have a love/hate relationship with 12.9 grade steel!/
I love making something durable, but I hate ruining my tooling.
P.S./Edit:
ISO 12.9 is a higher grade than SAE grade 8 - it compares to SAE ASTM A574
i use Mitsubishi. Have you tried Moldino? Mitsubishi Carbide bought them a few yrs ago. i have used some of their cutters on Ferralium 255Don't see Made in Japan too often anymore.
View attachment 366716View attachment 366717View attachment 366718View attachment 366719View attachment 366720
I just utilize what I have available, for the most part it works well, yet sometimes it is barely sufficient.have you tried a chip splitter end mill and H.E.M? do you use a Cad-Cam or program at the machine?
WiDia/Hanita, Osawa, Miller, Premus, Clarkson is what I use.i use Mitsubishi. Have you tried Moldino? Mitsubishi Carbide bought them a few yrs ago. i have used some of their cutters on Ferralium 255
ya cad/cam can be a pain, if you need to alter vs being able to do it at the controls. you like Hurco mills? i was intrigued by them when i was out at IMTS.I just utilize what I have available, for the most part it works well, yet sometimes it is barely sufficient.
For what I make I can not justify the purchase of more special tooling.
I have no access to CAD/CAM, everything is programmed on the machines console in WinMax and I actually prefer it that way as it is much easier to alter/adjust/correct/modify.
Again, can't justify trying them all - and honestly, no big difference between them.
The biggest difference is in the cutter geometry, some are ground more aggressive than others which makes them feed better in hard workpieces.
I am just a hack, I mostly don't know what I am doing!
first DMG Mori in the shop? looks like you will be getting CAD/CAM software after all LOL. unless you can program that 5axis mill turn in Celos.
