Lightning Performance
- 9:02 PM
- Jan 26, 2016
- East of Philly
You are making friends
Your making friends
Edited I did"You're"
Your a good dood.Edited I did
Use twoYour a good dood.
Thanc yuuUse two
I've often wondered about threading holes in the cylinder fins to use several short small bolts to hold a head on kind of like on model airplane engines. The holes should be as close to the cylinder as is safe, which may make the screws half in the cylinder wall. You might even fill the fin gaps with epoxy for more meat. You could still use the 4 big bolts, but just hand tighten the usual amount.Ok, here is what happened to mine. I have a head added to mine with 1/4" studs. I used a torque wrench each time I assembled it to 100 inch pounds. It was enough for the hardware, but too much for the cylinder. The flange at the bottom of the cylinder was bending with the clamping force. At this time I think I am done. I have the parts to make it stock and I think I will go that route. I'm sharing more so to warn others that are making a head that the parts may not hold up to the modification.
What about pinning (dowels) the crank pan and cylinder base together? Kinda like case halves on saws usually do. Probably need pins on each corner or close to itMy head is threaded, but you will need a way to grab the cylinder base and pull it in the direction of the case (down) the cylinder base cannot be allowed to have any vertical movement. Nuts would work fine if there is room for them.
Here’s a little methanol in the mix 50/50Here’s my pro entry first cuts hope you fellers like!
