Agent Smith
Hack of all trades
- 9:02 PM
- Jan 28, 2018
- Northeast ohio
Lightened things up a bit all aroundDid you fill the counterweights with lead for smoother running, or just going to lighten them?
Here’s my pro entry first cuts hope you fellers like!
Thank you sir!!Nice, liked the bore cut.
Is that elm?Here’s my pro entry first cuts hope you fellers like!
Red oak and Middletown nyIs that elm?
What part of NY are you in?
I'm from Rochester.Red oak and Middletown ny
Thank you sirI'm from Rochester.
Looks a little different from the red oak I am used to down here in TN.
Saw looks strong, nice work. [emoji846]
Like I should have never started reading this threadThey got *s-word you didn't even know you needed.
I'm going to regret this.That’s not good I have an extra power head if you need it
Yes sir I doI'm going to regret this.
Do you still have it?![]()
Just add a steel girdle to the bottom cap. Your almost there.Ok, here is what happened to mine. I have a head added to mine with 1/4" studs. I used a torque wrench each time I assembled it to 100 inch pounds. It was enough for the hardware, but too much for the cylinder. The flange at the bottom of the cylinder was bending with the clamping force. At this time I think I am done. I have the parts to make it stock and I think I will go that route. I'm sharing more so to warn others that are making a head that the parts may not hold up to the modification.
Yes sir I do
Better get on it Kenny....
