Terry Syd
- 2:08 AM
- Jan 18, 2016
- Comboyne, NSW Australia
OK, I get the power vs resistance analogy and how it won't be a linear increase in resistance. However, the 660 appears to have the extra torque to pull the higher gearing, maybe..
It appears we need to look at torque rather than horsepower. It will be the torque that twists the sprocket. A 8-pin is a 14% overdrive, so we need 14% more torque to twist the sprocket with the same load. However, using a non-linear increase in resistance due to the increased chain speed through the wood, the increased torque requirement will be in excess of 14%.
That sounds reasonable. Thus, the racer running a 10-pin is using a race chain with reduced resistance in order to run the chain speeds he does. Likewise, a Narrow Kerf chain is also reducing the resistance and thus dropping the torque requirements.
Hmm, now that I've argued myself into that corner, I've got to figure out why raising the cutting speed, say by porting and muffler mod (no increase in compression ratio), increases the cutting speed. The torque of the engine stays the same, it is just happening at a higher RPM. OK, so now were talking about increased horsepower, the ability to do more work.
Whereas using an 8-pin to increase chain speed (14%) relies upon a given torque figure, a modded saw that turns 14% higher RPM is using the same torque figure, BUT with the addition of 14% more power pulses to move the chain. Yep, that works.
Bottom line, if you want to turn the chain 14% faster, then pushing the torque higher in the power band is the easiest way to achieve the extra chain speed. If you are going to use a bigger sprocket to achieve the chain speed, then reducing the load (faster chain, shorter bar, smaller wood) is required. - I'm still having a hard time imagining that 660 not pulling the 8-pin, I thought they had more grunt than that.
So horses for courses, if your doing a lot of cutting of smaller wood or soft wood, you can get by with the 8-pin, it will just slow down some when you bury the bar and put a big load on it. If you don't want to use the 8-pin for the increased chain speed, you can spin the engine 14% faster with the resulting wear that occurs from the increase internal forces with the velocity squared function. - Compromises, always compromises.
Yeah, I agree on the harder wood and the cutter not wanting to take a bite, especially if the edge is off the chain. I'll pick up a 7-pin for my bucking saw and see if it improves the chain life. Crikey, I'm already on the spikes trying to keep the RPM down.
EDIT: It just occurred to me that maybe I should increase the cutting angle (drop the rakers) on a chain and see if that slows things down enough by taking a bigger bite, resulting where I can get an extra cut or two out of the chain. I'll get a 7-pin just in case it is too much for the saw.
