- 8:28 PM
- May 30, 2016
- Ct
Factory stock saw or has it been taken apart/messed with... ports changed/ported? Tank vent changed or modified yet? Carb inlet needle pressure tested?Wondering if anyone has dealt with the issue I’m having?
Saw will die coming out of the cut, unless I feather the throttle at the end of the cut.
Similar if I just pizz rev it and release the throttle without letting it down easy.
It floods. Only restarts with choke off and throttled and stumbles in smokey exhaust when it does start.
Took it to the shop I bought it from to put on the CST. No error codes, no updates necessary and they gave it a Reset.
Brought it home, no change.
Attached is a run today. I almost think it ran better today,,, harder to show the stall. Still happened three times though.
No stall on this run, but there’s a cut mid way through where it stumbles and finally recovers.
I meant to throw up a vid where it did stall.
