The 572XP Update Thread
7:28 PM
You still having problems with them? At work they seem to hold up better than the 462 Most of the guys seem to prefer them to the 462 anyway.
Not really. I found out that the tank vent was too restrictive. Since I started modding the vent, no more trouble.
farminkarman
I like the red & black ones
7:28 PM
Neenah Wisconsin
If you have a ported 572, I strongly recommend doing a vent mod like Randy highlighted earlier in this thread. I think the stock vent seems to be fine with a stock saw, but a ported saw obviously pulls fuel faster than stock, and the vent can’t keep up.
7:28 PM
I'm still trying to get you that oil pump drive Greg. :(
John7478
8:28 AM
Pomona Jail CA
No, if it needs rings it must be high use. Most Stihls just look beat after short time around here.
You really are butt hurt.
Now you're gonna insult me, and call me a liar because I'm sharing problems I've seen with a chainsaw?
You need to grow the *f-word up.
Have you two kissed and made up yet?
M2theB
8:28 PM
Central Mass
Wondering if anyone has dealt with the issue I’m having?
Saw will die coming out of the cut, unless I feather the throttle at the end of the cut.
Similar if I just pizz rev it and release the throttle without letting it down easy.
It floods. Only restarts with choke off and throttled and stumbles in smokey exhaust when it does start.
Took it to the shop I bought it from to put on the CST. No error codes, no updates necessary and they gave it a Reset.
Brought it home, no change.
Attached is a run today. I almost think it ran better today,,, harder to show the stall. Still happened three times though.
No stall on this run, but there’s a cut mid way through where it stumbles and finally recovers.
I meant to throw up a vid where it did stall.
Eccentric
Yes, we do have trees in Wyoming.
6:28 PM
Northwestern Wyoming
Did you get this resolved?
