XP_Slinger
They’re Just Saws
- 1:33 PM
- Feb 9, 2016
- Central NY
Pic thief034S KS and muffler baffle.![]()
I'd keep the KS and grab a Meteor piston.Looks like the cool pop up piston in my 034 has to go due to lack of compression, so, at this point is it better to go with a Meteor, 46mm piston set, or get a 48mm cylinder set and have essentially an 036? In other words is the KS cylinder special enough to save?
Agree. My builds are OEM jugs as much as I can.Maybe pistons, but jugs? Maybe not...might be a tad cheaper..
A cleaned up OEM cylinder is better than pretty much any aftermarket jug. You mention having time to check it out so eventually you'll get a chance to learn.I also save all my OEM cylinders, even if they're ruff.
Build quality absolutely! Some of the AFM ones are literally unusable.A cleaned up OEM cylinder is better than pretty much any aftermarket jug. You mention having time to check it out so eventually you'll get a chance to learn.
Just because it’s a KS jug, it doesn’t mean the performance will be better.Looks like the cool pop up piston in my 034 has to go due to lack of compression, so, at this point is it better to go with a Meteor, 46mm piston set, or get a 48mm cylinder set and have essentially an 036? In other words is the KS cylinder special enough to save?
Short of blowing the bottom end , I consider the saw a rebuildable item so I'll try just about any combination of cylinders and pistons. I recently built an 034 with an AF market big bore pop up kit , so far I'm pretty pleased with it. I have about 10 tanks through it now and dropped 5 trees with it cut alittle fire wood.
I don't sell saws as a occupation though or professionally build them , so I feel like if it grenades its self I'm the only one affected. If something doesn't work well I post about it if it's relevant, but I have 180.00 bucks in the running saw which includes the 25" ES Bar and its fun to use.
Ps. The oiler sucks
The previous comment about a pop up piston needs some comment .A cut pop up on a stock piston will not raise the compression. Because you are removing a portion of the piston face it will actually lower it but in effect raise the exhaust port . To raise the comp you have to mill the cylinder base just like using a flat top piston .
All a cut pop up might do is improve the scavenging above the intake port which may or may not be an improvement .
Now if you could find a piston that had a higher pin to face distance you could pop it and gain comp .What that piston could be I have no idea .I'm sure if you had enough money Wisco would make you one or a dozen .
