I call that a win right there.Ditto. Just runs so nice I haven't seen a need to go to 50 or 52mm top end.
Any of you arm twisters have any ideas thoughts
I'd wait for the Tecomec 365 cylinder to be on the deal of the day for $27 againMaybe the only thing I wanna try is modifying the zama carb that's on it. I'm also pretty sure it's a bit stronger than my 372 with the same bar and chain. Be it all my saws are stock except for MM,BGD and a little carb play. Also have a tecomec crank on the way for another build, most likely with 365 open port cylinder. Also read back through this post today and I'm also thinking on that jonsered 630 piston. Any of you arm twisters have any ideas thoughts?
Did it pick up any with the extra mods.The 036 I used the kit on has been cutting firewood for 3 1/2 years now. Just did a timing advance and muffler mod on it a couple months ago, still looked new inside when I pulled the muffler.
