Stihl 200t
Lone Wolf
11:07 AM
Nj
Wow! That is some cool info right there Steve! I never knew that. I always felt like my screwdriver was shot or the wrong size on them. Now I know why!!!
I suspected that to be the answer. I cant tell you how many Jap dirtbike front brake reservoirs I have stripped in 30 years. Well Im getting a new screwdriver soon thats for sure. I'm betting a lot of people dont know unless they are auto techs.
paragonbuilder
11:07 AM
Norwich, CT
Just ordered a set from the bay. I'm sure they will come in handy!
Thanks Steve!!!
Lone Wolf
11:07 AM
Nj
Thanks Steve!!!
What brand and do you know if its a number 1 or 2 sized tip ? To the best of my figuring I think a 1 will work.
paragonbuilder
11:07 AM
Norwich, CT
So I deleted the gasket and had .011 squish. So I sanded it with sandpaper glued on to the old piston. Got it back to .0165.
Bolted it up.
Opened up the exhaust a bit. Boy was it full of carbon.
All back together, fired it up. I forgot to trim the limiters, [emoji12], she was taching at 15,800!!! Holy crap.
Gotta trim those limiters. And put an edge on the butter knife chain[emoji33]
Lone Wolf
11:07 AM
Nj
Bolted it up.
Now what is the compression reading? What size exhaust port you have now? Or what percent larger?
Mattyo
Youtube speciawist
11:07 AM
Farmington, CT
Wow that's tight squish....
U get an edge on that chain yet?
Have fun! Congrats on getting her running!
paragonbuilder
11:07 AM
Norwich, CT
I didn't check compression. I like to get at least a little run time first. I'll check it tomorrow.
I cut open the port where the screen goes maybe 3/8". It could probably be bigger yet. I'll get a pic tomorrow too. And maybe a video...
paragonbuilder
11:07 AM
Norwich, CT
Great, thanks Steve. I'll see where she tunes too in a bit. Probably leave it a bit rich, I think I remember reading these saws are stronger tuned rich.
paragonbuilder
11:07 AM
Norwich, CT
Just checked compression. It's sitting right at 145. This is with new rings and 2 min run time last night.
Here is the exhaust mod.
I'm not sure how much they like to be opened up? Didn't want to make it to loud.
Trimmed the limiter and realized the high screw was bent pretty bad. Fortunately I saved a junk carb from a 192t and the high screw was the same. All set now.
Lone Wolf
11:07 AM
Nj
Why is it at 145 was this a refurbished cyl ? Did you use an old piston? Did you pull the saw 12 times or till it stopped rising?
paragonbuilder
11:07 AM
Norwich, CT
To be honest I forgot that my gauge is suddenly reading very low. The 346 I did I couldn't get above 135 and it was tough to pull over. So it's probably much higher than that... I need to get some new shrader valves...
New oem piston and rings. I'm sure it will get better as it breaks in too.
