The Badly fixed 200t needs fixin some moar
Wonkydonkey
Plastic member
9:22 PM
Sussex, UK.
An update on the saw, as it’s taken a back seat. I’ve still got to order the off spring and make the grounding wire. Also a new clutch drum needle bearing (ting ting ting)
However. After some looksee around here and there. I found the info from @Vintage Engine Repairs posts here and on AS and ordered the oring [1 oring]🤦‍♂️
I should have ordered a few more but I’ve now done this…
When I find the carb piston pump oring link I will add it here.
Edit:
Thread 'Accelerator Pump O-Rings (Carburetor Model Look-Up)'
https://opeforum.com/threads/accelerator-pump-o-rings-carburetor-model-look-up.30703/
In the meantime, here’s the saw with a not so sharp 14” bar on in some ash
