Stihl 1125 (034/034S/036/360) Cylinder/Saw ID
CJ Brown
6:13 AM
Belleville, Ontario, Canada
My 036 is an older one with the metal tag riveted on the recoil housing. It is so worn that I can't tell where it says it was made. The serial number does start with a 2 however.
I have searched images on google and found a few 036's with "Made in Germany" on the recoil cover tag, but that could be a case of someone swapping recoils or tags.
J_M____
6:13 AM
CT
Are you going to show piston differences too? I just pulled an 036 pro KS cylinder and it has the "winged" piston skirt. Most of the 360's I have seen have a normal straight skirt.
6:13 AM
Al,
My 034 had 2 muffler gaskets and a spacer, the bar is front adj, and the case will not accommodate switching,
and the rod is NOT skeletonized.
I love the 360 you did for me, but find the 044/440 much easier to work on (especially the oiler) and easier to make run great w/o any porting (or cylinder work, just delete the base gasket).
They both make real nice all around saws.
