Wonkydonkey
Plastic member
- 11:49 PM
- May 14, 2017
- Sussex, UK.
Here’s one of the links, I,m sure you can find the other one.
I'd like to see a pic of the jugs trans furs just for the pleasure of learning. I don’t think I’ve seen one like that before..(what I can see of it in your pic)
as others say mastermind cylinder cleanup should/will sort it if you take your time..
Over and over. You've asked for advice. Get it. Then do your thing. Only after a half dozen threads across a couple sites. Send me the jug, I'll set it on the shelf until I have a builder for it.I
it is quite rare it’s a open port 034 cylinder free for the taking if anybody wants it, I got a 036 p&c from shastonian on the way
Yah he's a bigger is better guy. Probably scrap the OEM.Open port 1125 46mm cylinders aren’t that rare.
The debate about open vs. closed ports is something I don’t get into. They both run and cut wood.
I would venture into the 46mm vs. 48mm bore debate, but not today.
Gotcha, man.
I hope to build up two more this summer if I have time. Both will be 48mm variations (because I have them in the stash) and will be testing some AM parts again (muffler and recoil... I need to know durability of both).
Side note- beware of AM throttle rods and certain carbs. The rods aren’t perfect and cause idle problems. Those Zama fakes we have mentioned before are hit or miss, too.
I put a vid of mine with a 25" buried in maple over on the video thread. It runs strong and I didn't touch the ports! Sooner or later I'll get up to Joe's with it and find out how strong on the dyno.a 034 super will cut with or better than an 036 I have both
You really shouldn't talk about things that you know nothing about.you don’t like stihls.
Your beating a dead horse boss.You really shouldn't talk about things that you know nothing about.
HoarderYou've got to be patient to get an 034S cylinder.
