hacskaroly
- 1:30 AM
- Nov 24, 2023
- Northern Idaho
I tore down my coworker's 075 to make sure the piston and cylinder looked good and came across this (see photo below)....a homebuilt shim that has been added. This is not in lieu of the cylinder gasket as that was on there too. Looking at the IPL, I did not see any shims like this listed. There have been several "modifications" I have found on this saw including the decomp hole on the cylinder plugged. Is there a good purpose for this shim? I know people generally delete the base gasket to gain more compression, wouldn't adding this ship effectively lower compression? Maybe this is being used to help the case from coming apart (grabbing at straws here trying to figure it out). Any thoughts about this?
