So what's the current two stroke oil favorite?
Inlineforagoodtime
12:14 AM
Earth
Does It idle 99% of the time it's running ?
I've ran it anywhere from 40-60:1 depending on who mixed the gas in both stock and ported saws..maybe even more or less and I can't say I've ever seen that happen.
I let the 362 idle while cutting or for a few minutes after making extended cuts or when I am moving branches. Ported makita 7900 doesn't have near as much.
I'm going to clean the 362 muffler when I get into the saber and see what happens.
sawmikaze
12:14 AM
steeltown
I never do things like this..
But I've been running my 400 a good bit the last few weeks and I'm gonna take the muffler cover off and see how wet the inside of the muffler is, I try to let these mtron saws idle for 10 seconds or so if possible after I use them..but usually not.
If it's wet enough I'm gonna use it for a blow torch and kill mosquitoes tonight.
Duce
12:14 AM
Roscommon, MI
How do you like that 400?
jakethesnake
I Am The Snake
12:14 AM
Here & Now
I don’t have a 400 or any good stihl saws but just curious
As far as the red armor goes I run a little leaner than a lot of guys. Maybe that helps.
I found my plugs getting fouled and stuff if they blubber too much.
I tried the benol also myself. Didn’t like it when it got cold outside. Stuff wouldn’t run right
sawmikaze
12:14 AM
steeltown
I'll never understand what makes people run benol in a chainsaw.
But I guess it's not for me to understand.
sawmikaze
12:14 AM
steeltown
So what’s that just kinda ridged it up a little?
I like a smooth AV, but not a system that feels like a threesome with 2 fat chicks in a half ton.
I even beef up my small saws. I put rubbers instead of foam in all my saws, I even took a buffer from a WCS kit and used it on the flywheel side of my 261s and 661s..makes a big difference when the saw is on it's side, doesn't feel like a diving board on the bar.
Personal preference.
