So what's the current two stroke oil favorite?
Stevetheboatguy
3:36 AM
Nw IL
I believe what you have is the semi synthetic hp but may be wrong
It may be something like that. I'm not certain on anything about it. I was at a auction and they had tons of it. I bought a pallet of it. Only piece of ope I owned was a ht75 pole saw. Only reason I bought it was because it was dirt cheap. I sold a bunch of it off and that's actually how I met my tree guy. He bought four cases and I tosses in a couple extra six packs that were loose as a freebie.
Looking back. I wish I would have kept more, but heck...... I had all the oil I needed for 7+ years after turning a profit..... I won't complain. Not often do I come out ahead on something like that. Normally I loose my azz.
Steven
lehman live edge slab
Live Action
3:36 AM
Mn
Steven
I’ll ask my buddy about this oil and see how long ago it was made and if and or why they quit making it
Moparmyway
Its just a saw
4:36 AM
In a meeting
I am starting to think or realize the debate with two-stroke oil. And I could be wrong. I think it has to do with the flashpoint of the oil of what it burns at. If the flashpoint is higher and takes more heat you get more oil in about a bottom end.
What temperature do you think the crankcase is on a running saw ?
Reason I ask is because I don’t believe that any oil flashes off in the crankcase, just whatever’s left that hasn’t flashed off from the fuel.
I believe that oil migrates through the crankcase and is carried in very tiny droplets or liquid form into the cylinder through the transferrs
Normzilla
1:36 AM
Cazadero CA
I'm not trying to start an oil war or super long post but I know there is a good chance I do.
I need to buy some more and want to know what folks are useing. Several years back I used some bel rat, the. Uses a few quarts of amsoil, then got some Lucas but quit when someone told me it left their says dryer and less oily residue than other worse oils so I quit useing it. I got a qt of Raiseman semi syn that I just used up last I mixed. I am going to have to use the last of the Lucas that I have untill I buy something else and was wondering what folks are useing these days.
Amsoil dominater. That's all I will touch
mrxlh
I stayed late and finished!
3:36 AM
Dat Boot
Here’s what your saw will look like on Ultra…
Ford3000
9:36 AM
No oil posts since July 30th, what up, did Biden sell all the oil,
and your all hard at work finding a replacent.
Ford3000
9:36 AM
All we need here is a wiper incorporated between the port and muffler,
the muffler doesn't look bad at all, seems it all sits in the port, piston
top doesn't look bad compared to most I have seen.
Even so, definite improvements could be made, wonder what the rings
look like.
Ford3000
9:36 AM
Can somebody educate me on the photos is that a lot of carbon buildup
Yes, its quite a bit of carbon, too much, the less carbon the better, if its sticky
soft it won't do as much harm, but when its hard, it breaks off and
because its so hard, it scores / destroys the piston, scores the cylinder
and if it gets above the cylinder in a big enough chunk it will damage the top
of the piston and the roof of the cylinder.
Basically there is nothing good about it, if you see or suspect carbon
is built up, then take measures to clean it out of the engine before damage
is done.
The Sthil oil mentioned seems to leave a fair bit of carbon behind.
Then again, use too much oil and it will build up and harden around
the port.
I use 40:1, and run the saw rich, its not too much oil when your saw
is hot and going flat out it burns it well.
DC1072
4:36 AM
South Carolina
is done.
the port.
Thank you for the input that’s what I have done I went over to 40 to one too because when my stihl 460 was rebuilt there was no oil in the bottom and it was rust color.
For years are used stihl Orange bottles always a little heavy on oil
Ford3000
9:36 AM
Thank you for the input that’s what I have done I went over to 40 to one too because when my steel 460 was rebuilt there was no oil in the bottom and it was rust color.
I know people who still use the orange bottle oil, never have any trouble, and they rest their saws for most of the year, stihl saws too, older models. I suppose the thing to keep in mind is, if you don't run enough fuel then your not allowing as much oil into the engine either, rich is what does it for me.
Echo PowerblendX and Husqvarna XP before that, but I only run up to 50cc saws,
so no need for a more viscous oil.
Ford3000
9:36 AM
Is that not straight dino oil, as in not synthetic, dino oil usually copes with keeping down rust very well.
DC1072
4:36 AM
South Carolina
It’s something that I don’t understand. My 460s 20 years old or more 22 I think the be exact. I ran it myself most of my life not a heavy user. Again I scratch my head over and that’s all I used to use was stihl orange bottles
Ford3000
9:36 AM
Would the fact you had your saw rebuilt not explain the lack of oil,
was it run lean, if so then more chance of moisture build up on surfaces
would also be lacking oil.
