So what did you do today?
czar800
7:36 AM
Ellwood City
It must be stock yet, that's pretty rare where I'm from, most had atleast 150 around here
It's all original and being a hydro I don't plan to put the screws to it....
Only if it was a 12 or 1456....... Someday I'll get one!
MG2186
6:36 AM
Summer,IA
Those hydros are pretty durable actually if you keep clean HyTran and filters in them.
exSW
'Cause Thomas is a poopyhead
7:36 AM
United States
In these parts he's doing the number one thing in that pic. INSIDE!
merc_man
merc_man
7:36 AM
southern ontario
Found some free sideing on a house that is gonna be torn down on tuesday. Its the same as i put on the addition few years back. So i spent a few hours tearing some off the old house. Will look better then the john mansfield siding thats on the old part of my house. Might go back on sunday and get the rest. Got about 2/3 done tonight.
And befor that was ahooting the pellet guns with my boy.
Now just sitting on front deck havin a beer.
Frank bierce
4:36 AM
Oregon
Went to a mini class reunion at a local lake yesterday... It was beautiful..got myself a little color..went straight from cracker, to lobster. Lol.
Guido Salvage
Supreme saw hoeder
7:36 AM
Farmville, VA
If this rain stops I will be pulling cedars out for a buddy that had about 40 acres clear cut.
PA Dan
FYD
7:36 AM
White Oak PA
Worked 8 came home and dug a section of french drain around the pool. Then I installed a couple beams for the deck. My gymnist daughter likes the beams!
67L36Driver
6:36 AM
Clean the carb. If it's a EU series and the Eco throttle quits working just buy a new carb. It's only a couple dollars difference than if you were to replace the control module.
Yup. My neighbor's generator had the throttle shaft worn and sucking extra air. New carb was like 25 USD.
Guido Salvage
Supreme saw hoeder
7:36 AM
Farmville, VA
Tried to move this IH truck and it lost all power, had to tow it back to the shop. Would not rev up and backfired heavily before it quit.
Cleaned the points and rotor, replaced the cap, pulled, cleaned and gapped the plugs and no joy. Points are properly gapped, no throttle response. Fuel pump is working, I am stumped, ran fine when started, checked the hydraulic oil and added fuel and it started acting up. 345 V-8.
Eccentric
Yes, we do have trees in Wyoming.
5:36 AM
Northwestern Wyoming
Bad coil? Plugged fuel filter? I had a 304 act like that when it had a flat cam lobe (#7 exhaust lobe). Just spit balling here...
hoskvarna
6:36 AM
Iowa
Timing chain jumped a cog. Get #1 cyc tdc then make sure rotor is pointin to #1 on cap. Had that happen to a dodge 360. Something to check.
Sent from hoskvarna hills
