So what did you do today?
Sloughfoot
5:33 AM
Norcal
never used SLIP, but I have used EZ Slide graphite paint in the past. It worked good, but you always had to re-apply it and now I can't find it locally (sold by Tractor Supply). I went with some $12 rustoleum oil base flat black this time.
I put a thick coat of SLIP on mine last fall. Hoping grass won't stick to it as much as it did to paint.
furb
8:33 AM
PA
Dug this out of the tool dump. Three drawers were in front of another building half buried and this was in the back of a junk truck. It was swayed enough from falling that the drawers probably didn’t slide and likely why it was apart. I beat it back to almost square. The missing drawer, slides and top struts are ordered.
furb
8:33 AM
PA
I've seen some angle iron used to span the box and then a handful of bar clamps on the ends of the angle iron, pull a couple of tool cabinets back fairly well.
I put a 2x4 on the bottom of the right side then beat on another 2x4 on the top left. I should have used a gentler method but that rusty fiskars sledge had a good wack to it. I clamped a Waterloo to a bench, clamped a piece of angle to pry against and straightened one that way but all my benches are buried with crap right now.
furb
8:33 AM
PA
singinwoodwackr
6:33 AM
moon
singinwoodwackr
6:33 AM
moon
Those are still my favorite saws for some reason
I might even assemble the one I have in a box now :p
Just need a piston.
I do have a model 50, 45mm nos piston that is the same size as the 350, just flat instead of dished. Will experiment… otherwise, meteor if I can’t find a cheap oe one.
This saw wound up with 150#, cold comp with new Caber ring which ain’t bad. No base gasket, .019 sq. Opened up the ex port and lower transfers to match the base, muff mod.
EFSM
7:33 AM
Extreme southern IL
Sloughfoot
5:33 AM
Norcal
