Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
Jimmy in NC
8:29 AM
North Carolina
Its decent work chain
Skeans1
5:29 AM
I've been liking that chain a lot.
What kind of top plate angle do you have on that.
42 inner top plate
20 top plate
2 degree side plate
I’ve played around with the settings on the slides and dressers but always end up right back there at the factory settings.
chipper1
8:29 AM
Grand Rapids Mi
42 inner top plate
20 top plate
2 degree side plate
Thanks, I'm around the same, usually a bit more on the top at about 25, cuts great and smooth as silk.
chipper1
8:29 AM
Grand Rapids Mi
You get a pro sharp?
I wish, sort of, I'd be more than pleased to get a new simington, but this old one has made some great cutting chains and the learning curve is only a little harder than a round grinder.
What are you using.
Skeans1
5:29 AM
I wish, sort of, I'd be more than pleaded to get a new simington, but this old one has made some great cutting chains and the learning curve is only a little harder than a round grinder.
What are you using.
Using a pro sharp has a pretty good learning curve with the way everything is adjustable, but the trade off is a better cutting chain normally more true side to side. If someone needs a manual for any of the Silvey square machines I think I have all 4.
Time's Standing Stihl
Below me...
8:29 AM
Central Iowa
What are you using.
After I sold the simington to @Armbru84 I picked up a pro sharp, but I've been using a file quite a bit lately
