- 9:11 PM
- Dec 30, 2015
- Centre County
Welp, at least you don’t ask for pics of the wood![]()
I've been liking that chain a lot.![]()
Stock
Straight off the pro sharp
What kind of top plate angle do you have on that.
Thanks, I'm around the same, usually a bit more on the top at about 25, cuts great and smooth as silk.42 inner top plate
20 top plate
2 degree side plate
I’ve played around with the settings on the slides and dressers but always end up right back there at the factory settings.
You get a pro sharp?Thanks, I'm around the same, usually a bit more on the top at about 25, cuts great and smooth as silk.
I wish, sort of, I'd be more than pleased to get a new simington, but this old one has made some great cutting chains and the learning curve is only a little harder than a round grinder.You get a pro sharp?
I wish, sort of, I'd be more than pleaded to get a new simington, but this old one has made some great cutting chains and the learning curve is only a little harder than a round grinder.
What are you using.
After I sold the simington to @Armbru84 I picked up a pro sharp, but I've been using a file quite a bit latelyI wish, sort of, I'd be more than pleaded to get a new simington, but this old one has made some great cutting chains and the learning curve is only a little harder than a round grinder.
What are you using.
Probably a work chain for his work saw.Just racing with that chain?
Ya. Did it on the grinder awhile back. Runs very good. Don’t have any work chain pics but I gotta grind a few soon.Just racing with that chain?
