Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
9:50 AM
kfd518
8:50 AM
Central Texas
You should be able o use the wheel up to a little below 6”.
hadn’t been able to find a measurement on that yet thanks for the info.
And then bush it down and run it on the 511:thumbsup:
I also hadn’t thought about doing this before. I like the way you think.
Paperwork says something about doing gullets on this thing but nothing about how to do them. I don’t mind hand filing them still as that’s how I’ve always cleared gullets but would be interested to know.
On another note how well would progressive depth gauges work on square ground/filed?
9:50 AM
It all depends on how aggressive your cutter angles are. I've had chains cut great at .020" rakers and I've had others need .035". Hard to tell for sure, but your bottom and side plate angles look really sharp
kfd518
8:50 AM
Central Texas
Need to get an angle gauge so I can get everything measured and set. Still haven’t figured out how to calculate included angles and all that. I hated anything besides basic mathmatucs in school and it’s caught up with me in several jobs. But I always seem to manage figuring a way to learn now as an adult when I need it.
Looking at the receipt the original buyer paid $562 in 1992 for this grinder.adjusting for inflation they have actually come down in price buying new.
brshephard
Stihl saws, Husky women
7:50 AM
MT
Simington used to sell an attachment for grinding rakers. Not sure if they are still available, but it looks like it could be adjusted to grind gullets.
Here is some literature that shows the attachment (fig 2):
Here is the thread I got that from:
https://www.arboristsite.com/community/threads/simington-grinder-thread-large-pics.153595/
I have a Simington modded by srcarr52 that can grind gullets. Might be an option.
kfd518
8:50 AM
Central Texas
I finally found it in the instructions. Step 11.) describes gullet grinding. If not hand filing them I may just do gullets on the Oregon grinder. It’s quicker for me to do them with file though.
Thank you for showing that. The Simington with the adjustable arm shouldn’t need the modifications but it might in the end I will need to play with it.
For this interested. Here are photos of the manual I received with this grinder.
Simington 451B manual
CF72731E-EC39-4F6F-8409-7D450F8CBFD6.jpeg 29AB9E3A-C807-4269-8FDE-ECEDDF50342E.jpeg E5E64F14-1DDB-42E6-8F63-D0E5893EA4A2.jpeg
Skeans1
6:50 AM
View attachment 154554 View attachment 154556 View attachment 154557
Setup your Oregon grinder to do rakers, I have a dedicated 511A just for this purpose and no reason you couldn’t do the gullets then either.
kfd518
8:50 AM
Central Texas
I do rakers on it already but can’t set it up dedicated to rakers. I do chains for other folks on it still. Either wa requires setup the Oregon requires much less though by means of no disassembly to do them.
Currently I grind all that needs to be sharpened then switch over to rakers. No change in the process, just doing square on a different machine. Would like some good photos of silver taker machine to see if I could replicate it.
Skeans1
6:50 AM
If you’re talking about the HDG Silvey grinder a knew a few guys that had them, their complaint with them was setup time vs using a standard grinder.
moparnut88
9:50 AM
US
There's a video of it on YouTube.
kfd518
8:50 AM
Central Texas
Wanting pictures of the motor hinge and the cut depth adjustment mostly.
On another note, worked with the grinder some more tonite. I set the side angle to 15* and top to 12 as was suggested earlier in the thread and came up with these.
794A024D-D4BC-4015-AFC9-C2C5783FE679.jpeg 6666112C-392A-4A4B-99AB-17160C977AF9.jpeg DE7B04F7-25F0-4A87-8D11-35A6350DC727.jpeg ED740E9F-3E44-4A50-8FDD-26BAA816627F.jpeg E77317E2-541F-449B-85A5-B80FA2C17D8D.jpeg
Time's Standing Stihl
Below me...
9:50 AM
Central Iowa
View attachment 154607 View attachment 154608 View attachment 154609 View attachment 154610 View attachment 154611
Your rakers look plenty low, with that much forward lean I wouldn't touch them.
Keep an eye on the corner, it looks a smidge high, but it will cut
kfd518
8:50 AM
Central Texas
It seemed that way to me as well about the corner but couldn’t tell if it was my eyes playing with me I noticed that last night about the gauges and checked them they are slightly above a..025 depth gauge measure gonna re check with straight and feelers later
