Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
jacob j.
Only the weird
10:31 PM
Coastal Oregon
Ya I noticed that. Practice practice practice. Lol. Shallower? Do you mean more flatter like the first stone that was on it or dress it even less of an angle than I have now? :)
More like the first stone is what I was thinking. I know you're trying to attain an angle that keeps the stone out of the tie strap but that first stone had a good working edge when I ground those three chains with it. The top plate angle was a little shallow for me but the backslope and side plate angles were good and I didn't get any beaks.
A.E.E.llc
Hello myself, its me again
1:31 AM
anywhere
Has anyone ever had a cbd wheel made for a silvey?
For a pro sharp yes, I know of someone that has. Would not work well for rs2. tho I've never operated rs2 the side plate angle changes drastic with different cutter lengths and brands.
paragonbuilder
1:31 AM
Norwich, CT
Can you explain this Shawn? The side plate angle changes from a new to a worn chain with the same angles on the grinder? I haven't noticed this. I'll have to pay more attention...
A.E.E.llc
1:31 AM
anywhere
You should have noticed it. The chain is riding on a arc. Angles will constantly change as cutter shortens.
paragonbuilder
1:31 AM
Norwich, CT
Maybe I missed it but I haven't seen anyone discuss having to change dresser angles between chains. I've sharpened about 39 chains now with the same dresser angles. I'll take a look later and see what kind of differences there are.
1:31 AM
I don't change my dresser angles, but angles do vary with cutter length as Shawn said
I never changed them as I ground chains down on the swing arm or RS 2. It's not enough to worry about for work chain unless it stops self feeding.
paragonbuilder
1:31 AM
Norwich, CT
So would you guys consider a cbd disc on the rs2?
paragonbuilder
1:31 AM
Norwich, CT
I just looked at a bunch of the chains I converted. You are right Shawn, the angles vary a bit. But not enough to matter for work chains IMHO. So if the disk could maintain the corner I think it would be worth it.
Thomas
10:31 PM
Galt
Anyone have a simington or silvey they want to sell ?
