Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
Miller Mod Saws
Chainsaw Masseuse
10:33 AM
Ravenwood,MO
Ok guys I'm used to machinist tools so I didn't have a protractor anymore and this was the closest I could find in town. I hacked it up so I could check to see where my dresser angles are for reference. Sorry no before hack pics. But you'll get the idea. Lol.
Miller Mod Saws
Chainsaw Masseuse
10:33 AM
Ravenwood,MO
On a machinist protractor. Where you see 45 is labeled 90 deg. But that dosnt matter. I know the 45 is a 90 degree corner and this dresser sits at 30 deg on protractor so the dresser is at a 15 degree angle.
Miller Mod Saws
Chainsaw Masseuse
10:33 AM
Ravenwood,MO
Ok new stone on and dresser angles changed. I know from talking and reading here. After I test ground the first chain and compared it against a stock stihl square ground. My cutter side plate has a lot more lean forward and the tooth has less angle. Making a lot longer ground top plate. Hope that makes since. So here's what I changed for the first go. IMG_0686.JPG
paragonbuilder
11:33 AM
Norwich, CT
Ok new stone on and dresser angles changed. I know from talking and reading here. After I test ground the first chain and compared it against a stock stihl square ground. My cutter side plate has a lot more lean forward and the tooth has less angle. Making a lot longer ground top plate. Hope that makes since. So here's what I changed for the first go. View attachment 46509
Cool. Let's see a tooth!
11:33 AM
Somehow I need to give the tooth less angle this way. This is a ground tooth. View attachment 46514
That's fine. I like 25° top plate unless my goal is durability over anything else. Then really semi chisel is a better choice. How much forward lean do you have compared to the rail holding the chain?
Miller Mod Saws
Chainsaw Masseuse
10:33 AM
Ravenwood,MO
And make the face of the tooth more blunt. So the purple arrow needs rotated up. This is ground so where my grinder is sitting right now. IMG_0690.JPG
junkman
Crush it
8:33 AM
pacific northwest
I like less angle there also ,there is a 7/16 size nut on the chain carriage ,loosten it and pull it away from the stone as much as you can and still grind and it will look like this .
