Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
11:18 AM
The grey one is the only one I haven't tried. Guess I ordered the wrong one.
Gray is my favorite when sharpening for others. Can clean up rocked chains in one pass normally. Just wears a lot faster than blue. 2 grinders one with it and then the ziggy with a blue would be best. That way you can get them square with the Simington and then if you want the other angles touch it up on the Ziggy
Deets066
AKA Deetsey
11:18 AM
Do all 4-5 produce the exact same chain? I know as my wheel wears (in diameter)it changes the profile of the cutter a bit.I can adjust the carriage to keep it close, but it still may be slightly off.
I smell what your steppin in, but think about it. Can you produce the same angles on a single chain throughout the life of a chain?
If you take a new chain and a new stone, each time you sharpen the diameter of the wheel is different and tooth length and size is different. Hard to produce identical chains, I only speak with experience on an RS 2, never used a square swing arm
Icepick69
Fart knocker extraordinaire.
11:18 AM
North Carolina
Yes, that's what I'm wanting to do on heavy rolled or rocked chains, then put on the other grinder. If the cutter isn't bad, doesn't take long to sharpen it. I'm just trying not to heat up the cutter.
That was my thinking
Icepick69
11:18 AM
North Carolina
But I didn't get the grey one. Just blues, salmons and one black (brown) one
11:18 AM
The gray makes a decent cutter. I don't think you'll be able to duplicate the angles on the swing arm to the ziggy. The gray will need to be dressed a lot more so I recommend getting 2 of them when you order.
Icepick69
11:18 AM
North Carolina
What I'm wanting to do, is get the rocked cutter close. Then finish on the ziggy.
My friends pro sharp won't duplicate the ziggy. It's just to old I reckon
11:18 AM
You can modify the pro Sharp to do better angles. I would like to check out your ziggy one day to see how close to race chain angles you could get for the bigger saws.
A.E.E.llc
Hello myself, its me again
11:18 AM
anywhere
I'm hoping from this forum to increase my business for offering a service to sharpen square chains. We sharpen ALOT of round. But would like to see more square coming in.
Also hoping to get into race chains, but race chains none of us has made, so it's all new. The cant racing at Randy's GTG has me hooked
Good luck on race chains. Hope you have lots of free time. More to it than just the "term".;)
Icepick69
11:18 AM
North Carolina
Here's what I deal with often, this isn't square, but you get the point.
I'm not complaining, I really need the work. I'm trying to figure out how guys sharpen a chain in 5 mins. I hear it all the time. But zoom in on the cutters. Look how the angles on right and left are.
This is what comes in my shop that needs sharpening.
Icepick69
11:18 AM
North Carolina
Any saw and consistent wood. Do steps modifying the chain to see the gains.
consistent Wood was taking away few days ago, lol.
I'm hoping to build a few chains after the new year, trying to get caught up rite now.
Maybe when you stop by, you can bring one of your saws
