- 6:18 PM
- Apr 30, 2016
- Central CT
Nice looking teeth! Should be throwing chipsMore pics of practice chain grinds.
View attachment 220568 View attachment 220569 View attachment 220570 View attachment 220571 View attachment 220572
Thanks Du-Hwane!!Nice looking teeth! Should be throwing chips![]()
Lol. No vids yet. Waiting for my neighbor to have 5 big oaks taken down. All the wood is being left here. Then we’ll have some vids.Gotta see these in wood. Vids yet? Lol
Surprised to see the Oregon sticker... Maybe that's just the stand?![]()
Saw this today for Depth Gauges.
Here is another one of their products
I dunno about this one, seems pointless on many levels.
I guess maybe if you're sharpening for hours on end...
The down stroke is triggered by the clamping pedal I'd assume?
Looks like a good way to burn up longer cutters if you're not careful setting it up or conversely having to go through the whole chain twice to hit the short ones.
It is "ergonomical" though... lol...
It’s an adjustable speed motor that is from a three position switch, the main reason for it is for consistent cutters for a harvester really both of these grinders are. When they walked me through the setup last year you unhook the grinder motor head and setup just like you would manually then rehook up the head.
The Oregon 610 or Super Jolly don’t use a foot pedal for the vise it’s hydraulic as the head comes down it clamps.
Sounds like the actuator rod must be a spring piston type deal run around on a cog at the end of a geared dc motor.
So then if the chain gets hung up (or the operator spaces out for a second) while moving between teeth, the grinder just comes down on whatever random spot it lands on regardless?
I guess it would be a good habit to run the chain around once before grinding so to avoid running into a burred out driver, sticky link or whatever...
View attachment 232743 View attachment 232742
Squared up this Raisman .325x.050 It has several tanks on it, in oak and hard maple. Noodle cut before picture really buffed it out! It's on a 16' bar cutting 8-11' wood except for some noodling cuts. I'm tickled with the way it has held up with such knife edge angles.
Thankful every time I use mine that you helped me get it sorted. Ewe are a good man Randy!You fellers make me wish I had time to play with my Simington.
