- 6:32 PM
- Dec 31, 2015
- East Jordan, MI
Squish band is supposed to be narrow from what I've read.
What size of a sprocket is it wearing? Looks like some hard woodHere's a 064 w/066 topend I just did a little rework to. It'll turn 13K with a lightish load, loves to work at 12K, and can be lugged down to 8K without even thinking of stalling.
Dodge made a huge chamber in the 426 Hemi, but they filled it with the piston.What I mean is,do you think a larger chamber not squish or a more narrow band affects performance?
I'm of the impression that chamber and piston shape, as well as size are directly related to each other. Chamber size should be kept as small as possible without going to far on compression. I'd rather fill a chamber with a piston than cut a tiny chamber. Surface area has to play a role in power output during the period that the fuel begins to burn. In my mind, pushing down on 6 square inches of piston with combustion pressure is better than pushing down on 2 square inches of piston with the same pressure.
That's what I always have been told.Dodge made a huge chamber in the 426 Hemi, but they filled it with the piston.
I'm of the impression that chamber and piston shape, as well as size are directly related to each other. Chamber displacement should be kept as small as possible without going to far on compression. I'd rather fill a chamber with a piston than cut a tiny chamber. Surface area has to play a role in power output during the period that the fuel begins to burn. In my mind, pushing down on 6 square inches of piston with combustion pressure is better than pushing down on 2 square inches of piston with the same pressure.
Do you think chamber size affects performance?
Say a 50cc chamber at 200lbs and a 70cc chamber at 200lbs
Think they will run different?
I don't know but I've always heard you want it small as possible.
Thoughts?
Be something that needs to be tested
Anyone make a Hemi piston and cylinder for chainsaws? Lol
The saw would have to be a 4 cycle to be a hemi.
Now I wonder if the 4 mix is a hemi.
Sent from my SPH-L710 using Tapatalk
Hemi is short for hemispherical combustion. The spark plug is at the top in them middle with a valve to each side. That creates a hemisphere. In a 2 cycle you don't have valve to create a hemisphere.?
Hemi, is just a half round chamber with a domed piston.
Don't see what 2cycle vs 4 cycle hast to do with it?
