Saw video thread
Chainsaw Jim
Con Artist LLC
1:43 PM
Springfield Oregon
Here's Don's poulan pro 505 making the first cuts after port work. Running the same bar and chain with 9 pin as the video before. rakers set at .070 depth
After all other mods but before any port work:
After port work:
I'd say this thing has a good bit left in it if it were to be a race saw.
Chainsaw Jim
Con Artist LLC
1:43 PM
Springfield Oregon
I don't know about a rwj.
What's it off of?
It's an oversized carb from the 372 x-torq. It's basically what you end up with if you completely hog out a wj39 to the limit.
It has the offset mount holes like the wj and will be easy to fit up.
4:43 PM
Here's Don's poulan pro 505 making the first cuts after port work. Running the same bar and chain as the video before.
After port work:
Running good. :pesas: I remember Tom Fales used to run them falling with 36" bars and he put finger ports in everything. Just have a different sound .
X 66 stang347 X
4:43 PM
Georgia
Why doesn't anyone sell ported cylinders W/ pistons using a saw stripped to the case to get the right port #'s. And then sell the ported cylinder and piston to someone to install and tune. Would that be a bad idea
Chainsaw Jim
Con Artist LLC
1:43 PM
Springfield Oregon
There are people who do on ebay. There are quite a few members who will grind a cylinder without the saw if it is something they have good experience with.
