Saw video thread
5:57 PM
Good thing the tree did not hit you. I would recommend a shallower notch and leave enough hinge, so the saw does not get stuck and then wedge it over.
Always get back when the tree starts to fall, especially if you can see it is not a clean drop.
Your life is worth more than the saw.
rogue60
7:57 AM
AU
Cool vid different way of doing it he knows how to cut a nice quota butt log for milling no waste.
What's the go with the "conventional notch" in logging hardwoods I see overseas on youtubes?
In all my years I've never seen it down here not with hardwoods and logging anyway or softwoods for that matter..
Hypothetically if a truck load of quota logs ever turned up all cut with a conventional notch we would say that's not getting unloaded here take it elsewhere.
We would buy logs by the cube same as all mills here..
Working out how many cubes are in a log is by measuring the length of the log then put a girthing tape around the center of the log ( barked yeah mills don't pay for bark) then look in ya little magic book and it gives ya the cubes for that log.
The reason is as a sawmill you would lose money buying logs like that.
Say as we did cut timber for railway bridges and you needed two 10x6 x 6m and you have a perfect log for it 6m long and the right size to get them out of free of heart but thanks to a conventional face cut one side is short! That's a difference of thousands of dollars that can't be made out of that butt log.
A good cutter ya tell him the lengths you want he would give you 50-100mm over on ya lengths or close to right on if no other options never under length, even mechanical harvesting they do the same with hardwoods.
Gives you a little to clean the log up a bit as you buck the log to whatever lengths the sawmill is cutting for orders and chit.
The conventional face cut is a waste of the best butt log timber you can't put that wood back on at the mill that side of the log is SHORT a total waste.
I don't get it myself surely the mills must deducted that lost timber out paying way less for butt logs cut like that? Even still I can't get my head around the waste at the stump if it's a industry wide practice.
Don't get me wrong not saying a conventional face cut doesn't have its place just mill logs it has no purpose it's nothing more than a waste of the best butt log timber.
Timjus
12:57 AM
Finland
[QUOTE=" Even still I can't get my head around the waste at the stump if it's a industry wide practice.
View attachment 323332[/QUOTE]
with humbolt you leave the wood in to stump. with conventional you can cut right at ground level
