- 1:35 PM
- May 30, 2016
- Ct
Your gonna want more hook than that, try handfiling it and pushing down more with the file. Or just change the stop on the grinder. You want to get the gullet.View attachment 294009 This is probably the worst I’ve done actually after looking at it. When I cut with the grinder 60 degrees chop and 30 degrees offset as intended it cuts like a normal chain no wow at all. Cut the rakers down as much as the saw will pull and still no wow. This one I put the grinder @ 40 and gave it just a light chop at the edge and rakers way down. Still no wow.![]()
