PA Dan
FYD
- 12:54 AM
- Dec 28, 2015
- White Oak PA
Thats debatable...Kettle!lol im ok coffee time
Hit the help center and continue. They did the same for me. Got mine back the next day.I must not be as good on my knees as you are
Touché.I must not be as good on my knees as you are
Touché.
Sorry bro
Love them both!After checking out the veteran's memorial display in town today (parade we usually have was canceled), I decided to do a little old vs. new testing in tougher wood.
This is a Western Hemlock log I've been cutting on - it's not particularly hard wood but it's very stringy and has a lot of tensile strength -
Great ass shots JJ. @Canadian farm boy can give you some pointers on improvements.After checking out the veteran's memorial display in town today (parade we usually have was canceled), I decided to do a little old vs. new testing in tougher wood.
lol, Mike has it down like no one else...
Here's one of my all-time favorites - the block in this motor is the earliest SP block I've seen yet and has port timing closer to a 797 than a traditional 125. The exhaust port is
low and wide and you can hear it in the exhaust note. It was a .020" over block when I got it so I threw a new .020" over Mc101 "nine port" style piston and rings in it. Chain
is new Stihl 46RSLH on a 7-tooth sprocket. It would probably drive a 9-tooth sprocket just fine.
Looks good buddy! I have one to work on soon! How did you do the muffler? @41FanForLifePlayed around with the modded 355t some. Still on its first tank. I haven't ran every top handle out there but this one may just be my favorite so far
I just matched the inlet, gasket and heat shield to the port and made a stainless cover with a 7/8" tube. These mufflers are pretty wide open already from the factory but with a restricted deflector bolted on. If i were to do someone else's saw, I'd just mod the stock deflector instead of a tube.Looks good buddy! I have one to work on soon! How did you do the muffler? @41FanForLife
Damn thats nice!I just matched the inlet, gasket and heat shield to the port and made a stainless cover with a 7/8" tube. These mufflers are pretty wide open already from the factory but with a restricted deflector bolted on. If i were to do someone else's saw, I'd just mod the stock deflector instead of a tube.
