Redmax GZ500 (husqvarna 450)
Mkinslow
12:25 PM
Tennessee
I've only dealt with one other redmax and it was a gz700 or 7000 can't remember. Wasn't a bad saw
Cut4fun
Redneck Chainsaw Repair
1:25 PM
Ohio
Few 450 I seen with issues have been carb or the seals.
Mkinslow
12:25 PM
Tennessee
Passed pressure and vacuum tests and I just put a new carb and all lines on it.
Mkinslow
12:25 PM
Tennessee
Ok so I got the new coil today, saw will start now. But its backfiring back threw the carb. I'm about to sling this POS down into the woods . I don't know what else to do
Mkinslow
12:25 PM
Tennessee
Fuel starvation? Is the fuel filter clean? You might back flush it to check it out.
Put a new one on when I started this adventure 2 weeks ago
cuinrearview
Handy dood
1:25 PM
Dowling, MI
Ex BIL bought a 460 at a yard sale once. Wouldn't run. Looked great through exhaust. Like new. Pulled the jug. Broken ring. That doesn't seem like that but strange things happen. Yours acts like the timing is off or the spark is weak or grounding out somewhere.
Terry Syd
3:25 AM
Comboyne, NSW Australia
I was going to say the same thing, but he just changed the coil, spark lead and plug cap.
What happens when you SLOWLY open the throttle? Does it begin to falter as it comes off idle?
EDIT: Did you ever try different gaps on the coil? Mine works best at .45mm, which is 'out of spec' according to factory recommendations.
Mkinslow
12:25 PM
Tennessee
I can somewhat feather it like in the video, but it coughs,backfires and dies.
Terry Syd
3:25 AM
If changing the coil gap doesn't get it, then I think it may be a foreign object in the transition circuit in the carb.
Can you slowly open the throttle, stop moving the trigger and let the revs build and then open it up? In other words, getting it past the transition circuit and on to the main circuit.
Mkinslow
12:25 PM
Tennessee
It won't rev any higher before it backfires and dies, Iv even swapped back to original coil and it does same thing. Iv changed everything that can be changed, p/c look great, swapped in every plug I have,reset plug and coil gaps. What's the chance that the flywheel is bad?
Terry Syd
3:25 AM
Crikey, this is a trouble shooting nightmare.
You changed the fuel filter, have you tried sucking on the fuel line to see if you can draw fuel? Maybe a crimped line or something.
Mkinslow
12:25 PM
Tennessee
Lol,choked on gas already doing that. [emoji2961]
