Husqvarna 562xp air leak driving me mad
Maxchaos
9:05 AM
Italy
Using a pressure/vacuum tester. Do you have one?
A friend of mine works at Husqvarna dealer,he has mityvac and Husqvarna software,I will probably ask him if I can borrow some tool,he is a good guy and sometimes I go there helping him,but have too much work for now to "waste" time with me
EFSM
2:05 AM
Extreme southern IL
Attach the tester to the primer side fitting on the carb. Plug the carb fuel inlet and make sure the carb holds vacuum (doesn’t need to be a lot, but should hold some).
Maxchaos
9:05 AM
Italy
Hi again.
I had time to swap some things.
So i swapped carb with autotune and coil.
With everything new the saw was bogging hard like It has no fuel.
With the old carb and the new autotune and coil the saw seems to work good.
So maybe was the autotune not good? Can It be possible?
Need to try It some more ☠️
