Play time?
Red97
10:10 AM
MI
The cut Times seem about the same, feels like it has more pull and less zing.
Still tunes out to 14k easy.
In the 20" bar vid I had the low side a little lean, slight adjust and it ran out fine.
I need to make a muffler spacer, bacj of the deflector is mighty close to the brake flag dont want to melt it.
Red97
10:10 AM
MI
10:10 AM
Used it to trim up some gaskets.
Yes Joe, I use a modded one as a template.
They came on 034S and 064. They work great to get an ex port outer flange ground to a certain size, then flip over and bolt through the muff/gasket/heat shield for an all at once matching to the port you just did with the same template.
Yours is custom and different I am sure. Nice to have a plasma table, huh?
