- 3:47 AM
- Dec 3, 2015
- Banner Springs Tennessee
Good info in this thread.....
Thanks for sharing.
Thanks for sharing.
Al, I'm pretty sure there is a roll pin that holds the adjuster screw in the pump. Also pretty sure the same pin acts as the limit stop.I need a bit of help on the oiler.
This saw has the pro oiler, but the stop on the adjustment screw is broken, so it jus turns.
It's not oiling so well. Very stingy. I have the screw slot perpendicular to the saw body right now.
Can anyone here tell me the proper slot direction for max oiling?
Lol. Ya think?Who's gonna set up an official Go Fund Me account for a cant stand for drf255? He could sure use one lol
And uses fuel it does.Yeah that cbf 026 is awesome. It really likes that 044 carb. Blows my mind that it can use all of that fuel.
You didn't set out to build yourself a Prius in this endeavor. Plenty of boring saws floating around alreadyAnd uses fuel it does.
Looks like your mods may eliminate the choke being pulled shut on these saws too!This pict outlined in black shows where I remove some of the baffle to allow air to move more freely from the upper filter area down to the carb mouth, Actually I remove the same amount on both halves of the filter,
This is a filter with the baffle ends removed, this allows a lot more air to get to the carb unimpeded,
The choke flap sits back /opens 0.525 on a stock filter and after I grind away the area I show in the pict the flap sets back 0.700 so an increase of 0.175 and the spring still has plenty of pressure to keep the flap retracted, also having the flap further back would allow more air to pass creating less vacuum or pull on the flap making it less likely to be pulled shut by a high revving engine.Looks like your mods may eliminate the choke being pulled shut on these saws too!
That's what I was thinking. Sometimes it doesn't take much!The choke flap sits back /opens 0.525 on a stock filter and after I grind away the area I show in the pict the flap sets back 0.700 so an increase of 0.175 and the spring still has plenty of pressure to keep the flap retracted, also having the flap further back would allow more air to pass creating less vacuum or pull on the flap making it less likely to be pulled shut by a high revving engine.
