Pick the best carb for MS260 Pro...
paragonbuilder
12:52 AM
Norwich, CT
Yup. I installed it and it wouldn't hold any pressure. Put the old one back in and it's fine.
bikemike
11:52 PM
Cottage grove mn
Rebuilding my 260 carb and it's got a wte549?
As I was installing the diaphragm for the metering lever I noticed this
Seems to me that would be like drastically changing the metering lever height. Any thoughts?
Might need an extra gasket for that.
paragonbuilder
12:52 AM
Norwich, CT
So how do you know where to set the metering lever with this? Just need to try it and adjust?
Basher
1:52 AM
Canada
Was the gasket that came with the kit a much thicker one than normal?
Basher
1:52 AM
Canada
Deets,
A new 194 will set you back $38. A new 403B around $18, but you'll need to modify your tank handle for the mix screws. Venturi should be the same. Runs just as well.
The Tillotson HU is a problematic carb anyway, that plastic module is a known trouble source for these HU carbs.
stihl_head1982
Here long time
12:52 AM
USA
I think I learned this the hard way. Why am I always learning this way ...:facepalm:
paragonbuilder
12:52 AM
Norwich, CT
I'm not sure. However with the metering lever set flush with the carb body and the new gasket it would not hold any pressure. So it wasn't thick enough... I put the old set back on and it's running fine.
DND 9000
6:52 AM
Germany
Hi paragonbuilder
Have a look at the file attached for adjusting the metering lever height of the WTE carburetor. It`s the same procedure also for a Walbro WTF carburetor on other models.
12:52 AM
Pretty scary Dan. Looks like a mistake anyone could easily make.
paragonbuilder
12:52 AM
Norwich, CT
Hi paragonbuilder
Interesting... I thought walbro's all were set flush... And that's how it was...
Maybe it was kitted before and done wrong?
So seems to be running good, I have not cut with it yet, but seems doggy on spool up. Could this be why?
What does this setting actually change in regards to function of the carb?
DND 9000
6:52 AM
Germany
Maybe your L needle needs to be a little bit more open, that gives normally a better acceleration.
