Terry Syd
- 1:17 PM
- Jan 18, 2016
- Comboyne, NSW Australia
I don't know what the air filter on the 026 is like, but on the 029-039 series it is pathetic. I made up my own filter by removing the felt from an 029 filter, drilling the cage, gluing some thin filter foam over the cage and then sewing some flannel from an old shirt over the whole thing. It increased the surface area probably 300%. It actually filters better than a stock filter, probably because there is less suction to pull stuff through.
I did a test one time of the filter. I had used the saw three times without cleaning the 'high-flow filter'. I had a tach on the saw and ran it up to WOT to get a reading, then I put on a brand new, never used, stock filter and checked the RPM again. The clean, new stock filter showed a 75 rpm drop. I didn't bother testing a dirty stock filter.
Bottom line, if the filter is the bottle neck in the intake system, then a bigger carb isn't going to improve the air flow.
