Part Two: The Intake Port
XP_Slinger
They’re Just Saws
2:44 PM
Central NY
Moparmyway
Its just a saw
2:44 PM
In a meeting
The theory behind that is because the intake is going from a greater pressure,atmosphere to a lesser pressure,crankcase that this creates a cooling effect .This in turn would have a tendency to cause the fuel /air mixture to condensate on the walls of a mirror smooth intake track as opposed to a vapor like mixture .
Except that the drop in pressure will cause any liquid to flash off easier
Finally found a use for Save Edge
I've gotten some new ones that wouldnt wittle a wet noodle in a day of tryin
2:44 PM
My guess is the smaller one.
Exactly.
Air flow dynamics play a roll here. The intake port flows from vacuum and not pressure. Make it too big and you'll lose vacuum and the midrange of the saw will suck. The top end may be better with a bigger port.
As the piston rises and the case creates negative pressure the port starts to flow. Make the intake too large and it has an effect like making the case larger in some respects. The vacuum and flow that's created isn't perfectly linear.
Hope I'm explaining my thoughts correctly. Then again, doubt too many care.
XP_Slinger
They’re Just Saws
2:44 PM
Central NY
Exactly.
Hope I'm explaining my thought correctly. Then again, doubt too many care.
Great info. You nicely illustrated how bigger isn't always better for a work saw. You've put a big question in my head to rest. That's what this series of threads is all about! Thanks Doc.
2:44 PM
I have limited real world experience. Many of the guys here have tons more. I try to pay attention to what the big dogs here have said and incorporate into what I do.
Take my opinion with a grain of salt. It's worth what you just paid for it.
Moparmyway
Its just a saw
2:44 PM
In a meeting
Exactly.
THIS !!!!
1. Hope I'm explaining my thoughts correctly.
2. Then again, doubt too many care.
1. Perfectly Doc !!
2. :facepalm: You couldn't be more wrong if you were paid to be
Member
1:44 PM
Exactly.
Your grasp of the subject and wonderful explanations of same are just absolutely excellent. Thanks. :)
Simondo
7:44 PM
UK
Yes....and yes. Yes, that too.
The reeds are just on the strato ports.
If memory serves me.....you "Contaminated " ! :D ...that on the 6100 reed valve stratto feed ?
XP_Slinger
They’re Just Saws
2:44 PM
Central NY
How bout finish?
I like to hit with 100 grit emery on a split mandrel and then bead blasted
I like that idea. I've always stippled it with a double cut bit, just kinda letting the dremel bounce around with light pressure. I'll be plagiarizing your method on the next one I do. Gladly pay a royalty...lol
