XP_Slinger
They’re Just Saws
- 12:40 PM
- Feb 9, 2016
- Central NY
Exactly Stump Shot. If the intake is open too long case compression will not build to an efficient level resulting in a lazy charge entrance as it comes through the transfers. I get why some guys trim the skirt but it's very easy to go too far. In my limited experience, a base gasket delete will net you around 3 degrees of additional intake time if I recall correctly. That's just lowering the cylinder by roughly .020" give or take. Now imagine you're trimming your skirt so it's not protruding into the port window at TDC ( not a problem I've seen yet), lets say its 1/8" that you're trimming off, that's .125". Translate that to time gained in degrees using ".020 = 3 degrees gained" and you would have gained a whopping 18.75 degrees of intake time. Translation = Intake closing much later producing what would most likely be very poor case compression. What is the right intake time to get the right case (primary) compression? Question of the ages! Different with every saw most likely but I'm speculating on that. Keep in mind that the trimming number I used as an example is highly impractical but I hope I've helped further illustrate the importance of Intake Time vs Area.
