- 10:52 AM
- Dec 3, 2015
- Banner Springs Tennessee
I have exactly zero experience with E85.
Just a little more than the piston diameterWould that be roughly about the diameter of the piston? More? less?
Pop ups have their place, if you have a jug that is timed very well and you just want a compression increase then you should use a pop up.How about when You should or should not use a pop up. Pros n cons
Step 1. Buy stihls in boxes
Step 2. Fix stihls
Step 3. Sell stihls
[emoji12]
I put this one straight on cl. But I guess no one in Ne Kansas needs a saw right now.Have to flip on Craigslist. This is a small market and we all want them dirt cheap.
What are you trying to sell?
The highest power diesel engines are around 12.5-13:1 with crazy boost. Too much compression and a smaller chamber can lose powerGood post Doc. In addition to heating the charge closer to combustion temp, higher compression also gives you a harder push on the piston. Which gives the crank more inertia to keep rollin once the burn is completed. The end result being a very real increase in torque. Extreme example would be Diesel engines. Ridiculously high compression with torque typically double its HP output but a low rpm range. Not trying to side track the thread with rattlers, just an example. I think this is a given that most understand but figured I'd throw it in here. Finding the right amount of compression for a given saw is like everything else in this series, we have to experiment to find that balance.
