- 12:42 AM
- Jan 17, 2016
- cape cod ma.
Rule of thumb for making power. High compression for gas motors and low compression for diesels.
Play with a few diesels back in the day. Used to lower comp a bit so you could get more fuel without
increasing cylinder pressures. Also play with cam timing. Especially on the 855 Cummins with cam
operated injectors. Slow the cam down which is retarding. That lowered cylinder pressures a bit and
then you can add more fuel. More fuel, more air, more power. Had some mean running Cummins
back in the day.
back in the day.
