Oxygenated fuel in saws do’ And don’ts
  • Thread starter Thread starter ADMO services
  • Start date Start date
A
ADMO services
Guest
No rocket powered saws here so unfortunately won’t be using hydrazine
A
ADMO services
Guest
Or I could just hook a neon light transformer to my spark plug and up the compression to 350psi then run it on rc fuel! Just have a spark plug to start it! Jk
A
ADMO services
Guest
Top fuel only uses the plugs for takeoff they melt by the time the car is hooked
USMC615
Fapper Fi
4:04 AM
Mid-Georgia
Interesting thread...out of my realm but following to see where this saw goes.
A
ADMO services
Guest
Might be a while, be patient with me. I’m tracking down parts needed for my piston swap atm
EvilRoySlade
What’s my line?
4:04 AM
Michigan
Hydrazine!
The building I was in last year had 300 gallon totes, we would go through one in about a day and a half. I considered using it in the fuel but after some study and history research I decided I wasn’t keen on hanging onto a bomb.
A
ADMO services
Guest
That type of hydrazine you are speaking of is diluted and used for corrosion prevention most likely in piping as it is an oxygen scavenger. Pure hydrazine is used as a satellite propulsion fuel and would never be able to be handled in open air as risk of explosion.
A
ADMO services
Guest
Elliminox is a common brand of mild hydrazine and it’s mostly water
