Oil questions...
Partner
1:56 PM
Poland
Somewhere I have photos of the muffler inside with the lard so I need to add cracklings 😉👍 I don't know if I published it here
lilspenny
6:56 AM
Two cycle oils dont have VI improvers..
I was wonder about that, so I Googled a bit and found some info,
which led me to looking up Echo Red Armor's composition, which showed polybutene. So, I Googled (polybutene viscosity improver) Well, it seems that polybutene can be used as a viscosity improver, which is also known as a viscosity index improver. I rely on you for good information. Your thoughts?
I
Bwalker, I was looking up polybutene ( in Echo Red Armor 2 cycke oil ) and other chemically related substances and from what I read it seems that polybutene can indeed be used as a vii. So since it is in Red Armor 2 cycle oil would it not only act as a smoke reducer but also as a viscosity modifier/viscosity index improver?
and from the dl chemical company website....
2025
D.POLYBUTENE
The world best POLYISOBUTYLENE
Product Features
Eco-friendly ProductsNon-toxic, non-irritating productsSuperior chemical stabilityChemical stability to heat, reagents, and UVPerformance EnhancementMaximize product performance for industrial lubricant applications as Viscosity Modifiers (VM) and Viscosity Index Improvers (VII).
I have a question... Since polybutene is widely used as a viscosity index improver as well as a smoke reducer and dispersant is it not performing the role of a viscosity index improver in Echo Red Armor? How does it not perform such a role of vii in 2 cycle oil if part of the composition?
Motorka
1:56 PM
EU
With all the knowledge you could make jour own oils... or for beginning blend two or three types .
bwalker
7:56 AM
Montana
I
2025
D.POLYBUTENE
Product Features
Poly iso butene is used in almost all modern two cycle oils as a anti scuff additive. Its what replaced Brite stock in the old two cycle oils because it burns very clean. Its not used as a VI improver in 2 cycle oils.
VI improver are used in multigrade 4 cycle motor oils to provide the span from the low number to the high. If that makes sense.
bwalker
7:56 AM
Montana
I
2025
D.POLYBUTENE
Product Features
Its not used as a dispersent in two cycle oil. It is used as a clean burning low smoke base oil. And no, its not a viscosity improver because red armor is not a multi grade four cycle oil.
Of course there are different grades and weights of PIB used for different purposes.
PIB is also the product used in bar oil that provides the tachiness. Sometimes called paratach.
lilspenny
6:56 AM
Thanks for your reply!
lilspenny
6:56 AM
VI improver are used in multigrade 4 cycle motor oils to provide the span from the low number to the high. If that makes since
Yes, thank-you sir! I'm glad you could answer. Edit starts here. You are a "sir", right? lol
bwalker
7:56 AM
Montana
In addition, PIB's used in two cycle oils are designed such that the "unzip" cleanly into combustible gasses once they reach a certain temp. Esters do the same sort of thing.
PIB's used in VII for 4 cycle oils are designed for the opposite. They are designed to be extremely stabil and sheer resistant.
Partner
1:56 PM
Poland
Us is a free country 🤠 I have 2 dealers Stihl within 5 miles and neither of them has it
Tomos770
1:56 PM
Slovenija
@lilspenny .....to enlighten you....since you are such an Ultra fan :D (was banned on BITOG in the past....so can not comment there)
Stihl Ultra in UK is still ISO L-EGB.....
Proof: https://www.stihl.co.uk/en/ap/hp-ultra-two-stroke-engine-oil-1467
  • Performance standard: JASO-FD, ISO-L-EGB, oil/fuel ratio 1:50
If it is ISO L-EGB.....then it can not magically be JASO FD.....since JASO &ISO are almost the same standards ...
7:56 AM
It’s fb rated.
There is an HP Super that is FD rated but not available in the US
lilspenny
6:56 AM
Yep...but it clearly says FD. The other day I checked and it said FB. Can't have it both ways unless a certification is lagging. I commented... asking Stihl about 4 days ago.... crickets.
