Bigmac
- 2:24 AM
- Apr 19, 2018
- Oregon
I have been gifted a troubles saw, an MS 500 that the dealer doesn’t want to touch. It would start an idle and sound OK and lean out if you put under any load, then I did the simple things and pulled the fuel filter to check to see if it was clogged and it was fine and pulled the throttlebody cover off and blew out all the chips and now it doesn’t want to restart on its own. It will start and run with a prime.
The primer bulb would not pump fuel well, unless the fuel cap was released, but it still wouldn’t run well with the fuel cap off.
Any help or ideas are welcome
