MS460 Teardown-Comments Welcome
mdavlee
Hillbilly grinder
9:34 PM
TN
I think the 661 with a maxflow and a good fitting cover would rival the 394/395 filtration
You can go weeks sometime on a husky filter. They stay so clean you forget to clean them. The max flow may filter fines better though.
Until I get more time on one to say it's got the 395 power I'm unsure. My main use for a 90cc pcc saw is milling so I'd like to get a few cuts on one. The lower rpm mtronic coil may be best for that. The higher rpm one is probably better for short bar stuff. I do want to see an unlimited one with a good chain in some cants.
Landmark
Chainsaw Hack
9:34 PM
WNC
Not trying to derail ur 460 thread but i need help on my 046 and figured you still guys will know. Tried to run it yesterday and its not oiling. Tried to adjust and no good. Took bar and guide plate off and started saw and it def not oiling. Took oiler off and made sure tubes and oil pasages and vent are not stopped up. All looks to be good. So is there any way to verify its the pump other than putting a new pump on it? (Worm gear looks good and bell is catching and turning it good)
Landmark
Chainsaw Hack
9:34 PM
WNC
Did you check the screen / filter inside the tank at the end of the hose ?
Yes. All clear
The wire drive could be slipping on the worm gear. Seen it many times
Could be but when i am turning by hand with oiler off it spits bubbles. The bell seems to be on the wire good but will double ck.
