McCulloch Super Pro 125c build thread
Bigmac
2:10 AM
One final detail - on the left is the big bore saw and on the right is the standard SP I built earlier in the thread. The big bore saw has the wide handlebar that was designed
for the later saws that came with a chain brake. It uses an extension bracket to mount to the tank. Guys that have milled with 125s like the wider handlebar a lot more, as
it provides more room for accessing the clutch cover. I knew a guy that was using 125s to build a log cabin in BC years ago and he would run the wide handle with a cut-down
clutch cover. He wore out three saws by the time his cabin was done.
That’s cool, I have a wide wrap, but no bracket! I have wanted to try a modified cover on the sp, the cover doesn’t clear chips well I have thought about modifying a 250-300 cover, because they are cheap, I haven’t fit one on a 125 though, but have seen some guys run them, the back line is too vertical and too close to the clutch, I think it hurts in long bar use
jacob j.
Lord of Cargo Pants
2:10 AM
Coastal Oregon
I think people mod the 250-300 covers a lot when running them on the 125s - I've seen quite a few.
I got a bracket for you for your wide handle. I think I have three extras.
sawfun
2:10 AM
Portland Oregon
That's good to know Don - I'm thinking about building a gear-drive this winter. I'll probably use a stock SP motor.
I only know of McBob doing it. Bending the oil pump rod is the very tricky part, I've ruined one already ugh, with measuring the location of bends and the twists necessary. I am in the middle of a cp125g build, though have given thought to returning it to direct drive with today's prices. I have an sp125 that might be better suited. The cp's AV seemed easier to build around. McBob used a cut away sp oil tank as I recall. The gear drive stuffer needs material removed the same as when doing the 797g conversion. Make a front mount off of the steel plate behind the stuffer and your pretty well set.
Lee H
2:10 AM
cape cod ma.
Also all the SP105's got the thinner side covers. All the sp125's I have had and seen all
had the wide covers. CP's had the thin ones like bigmac stated. The SP's with wide cover
also had a longer starter drive.
I like the early original logo way better than the new one.
jacob j.
Lord of Cargo Pants
2:10 AM
Coastal Oregon
I thought you guys would enjoy hearing the big-bore saw running for the first time. It's a beast to pull over. I haven't put the compression tester on it but I'm guessing it's
right at 200psi. I have to change the tank though - this one has a slow leak on one corner.It's got the modified Promac 650 coil on it that my dad fixed up - I think I'll swap that out. The timing on it is super aggressive.
Bigmac
2:10 AM
Sounds good! How much over bore?
jacob j.
Lord of Cargo Pants
2:10 AM
Coastal Oregon
It's a .030" over cylinder with a new .030" over slug and rings I found on e-bay many years ago.
The 101 saw of my dad's is .020" over and I've got an Mc-91b motor to put in a 795 frame that's .040" over.
Somewhere in my stash I have a .050" over 101 block.
Bigmac
2:10 AM
That’s cool, over bore sp pistons are hard to come by now! I think Terry is making one for Mike in the cp, Mike would know better, I haven’t gotten one from him. The kart saw I posted the video of is .024 over, it was a worn out .020, and an original saw block, I bought a lot of parts on eBay and it came with a .024 piston and 101b rod. So only a hone to fit the piston! Terry has a ton of piston options for you if you need, .024 .028 and .030 I believe, the kart motor in my current build is .004 over.
how do you like that 91b/795?
Bigmac
2:10 AM
p61 western
Ol Mudflap
2:10 AM
GFY
Yep Terry can make just about any piston you need. He tried buying the tooling to make rings, but they wouldn't sell it to him. He was not a happy camper lol. That said he has no problem getting the rings either. I need to get my azz down to his place soon. It's cool just bsing with him.
Bigmac
2:10 AM
Ya you need to get there! This was your thread! Slacker! Lol
jacob j.
Lord of Cargo Pants
2:10 AM
Coastal Oregon
I'm looking forward to putting together the 91b/795. It was a race rig before - part of the tank was cutaway previously and it has a custom round tank that bolts on top. It has a stock bore 91b in it that's really tired. The block will need bored over - I'm sending it to Terry in about a month. I have a full-circle crank for it as well. I'm going to have Terry bore it out and match a piston for it. It has the vertical kart V-4 intake and a BDC carb on it. I'm gonna swap that out for a V-6 Christensen intake and twin HL-224s.
jacob j.
Lord of Cargo Pants
2:10 AM
Coastal Oregon
Yeah Mike, you need to get cracking and take back over your thread...:2guns::rocket2:
Bigmac
2:10 AM
That will be cool! Looking forward to that! I have wanted to do a 100cc kart Mac too
